Front End Setup
  • This topic has 1 reply, 2 voices, and was last updated 7 years ago by David Faulkner.
  • #25236
    Nigel Watling
      Hi All
      Looking to set up Castor, Camber and Ride Height on my 1951 Light 15, I can see how to adjust Castor and Ride Height but is Camber spec for checking only as can’t see how it can be adjusted, any advise would be much appreciated.
      At present time I have 1.5 Positive Chamber on N.Side (just in spec) and 2 Positive Chamber on O.Side ( just outside spec)
      Nigel
      #25237
        In the workshop Manual, operation 149 and drawing 45 are what you need to refer to. If you don’t have a cop[y you can download one from the members area  https://traction-owners.co.uk/wp-content/uploads/2017/01/Light15_Manual_1938-5056_Print.pdf
        Basically ‘Wheel Camber cannot be adjusted’ – if out of tolerance ‘1 degree plus or minus 0.3 degrees’ then it says check the axle parts and hull alignment
