Fuel leaking from vacuum take off
Traction Owner’s Club Forums Technical Engine Fuel leaking from vacuum take off
Viewing 2 posts - 16 through 17 (of 17 total)
  • #27126
    Norman Anderson
      Hi David, you’re right about the rich mixture. This is definitely running rich. It needs no choke at all when starting from cold. I haven’t looked at the fuel consumption yet, but it doesn’t appear to be great. I guess if it needs to be addressed, the only way will be to change the main jet?
      #27127
        Norman,
        Can you not weaken the mixture enough by screwing in the mixture screw ?
        If you have a “Colourtune Plug” you can quickly check and see the imediate effect of any adjustments although the plugs are the best long-term indicator of  a good fuel/air mix.  If you don’t have such a magic plug, I would suggest tightening the mixture screw no more than a quarter turn at a time and then running for a while before checking the plug colours.  And you will probably have to adjust the idling to maintain optimum tickover as the mixture is altered.
        B……
