Headlight mounting plinth Lt 15 RHD Drivers side
Traction Owner’s Club › Forums › For sale & wanted. Suppliers › Wanted › Headlight mounting plinth Lt 15 RHD Drivers side
Viewing 15 posts - 1 through 15 (of 15 total)
  • #24289
    Tim Greg
      Hi There, does anyone have (or can point me towards someone who has) a drivers side headlamp mounting plinth (that the headlamp fits onto) for a 51 Slough Lt 15, complete with captive bolts. One of my bolts is missing having pulled out of the plinth i suspect.
      Thanks Tim
      #24291
        Is there any difference to a French car? The spare parts (English list) in the members area has them at part number 298202/3 same as the French parts list online elsewhere.
        If you can confirm they are the same I have a pair you can have as I fitted chrome ones.
        #24292
          Managed to dig them out of the back of the garden shed so you can see what they look like to compare:
          (Top and bottom views)
          Headlight_mount
          #24293
          Tim Greg
            Thanks David. I am 90% certain they are the same, confirmed by the fact of there is only one part number around, would yours be paintable in your view?
            I would be glad of the drivers side one – what would you want for it?
            Rgds Tim
            #24294
            Tim Greg
              Yes that it,  are they the same both sides L and R do we think? I need drivers side RHD.
              #24295
              Tim Greg
                Hi David
                I have checked on a European website and looks like they are the same Slough and France, but different Left and Right.
                #24297
                Patrick Russell-Jones
                  Tim
                  The part number you need is 9547 RH. The mountings are different to the French ones assuming you have the original Lucas headlamp units. See photo.
                  IMG_1975
                  #24298
                    Gents,
                    These brackets/plinths are definitely handed and the French ones are equally definitely not the same as the Slough parts.  There are two main differences ……
                    1) As Patrick says, the profile of the domed top (to match the recess in the lamp) is not the same for the French (Marchal/Ducellier) headlamps as the English (Lucas) version.
                    2) In addition, apart from the very earliest versions, the French parts have a slot to access the lamp fixing nut.  This is clearly visible in David’s pictures above.  Slough parts never had that slot.
                    I may have possibly have one in my stock.  I shall check when I get into the garage later this week.
                    B……………
                    #24299
                    Tim Greg
                      Thanks to every one, I have not got the car nearby to check, but thinking about it I dont think they have the slots, and I do have Lucas lamps..
                      So Thanks Bernie, let me know if you have a drivers side one you could let me purchase.
                      Tim
                      #24304
                        If Bernie doesn’t have one I’ll ask James if he has one from the car he scrapped last week.
                        #24305
                        Tim Greg
                          Thanks David.
                          #24307
                            Gents,
                            Regret I have 3 Lucas headlamp shells  but no plinths.  Sorry.
                            So, over to David/James.
                            Good luck.
                            b………….
                            #24308
                            Tim Greg
                              Thanks Bernie, David I would appreciate you assistance if that`s possible.
                              Thanks Tim
                              #24309
                                Sorry, spoke to James Geddes this morning and he hasn’t got any Slough headlight mounting plinths. Apparently it’s quite common for the bolts to shear off them.
                                If your careful you can repair them, however there are 2 types,  earlier ones made of brass (stronger) and later ones from a form of white metal alloy which is more fragile.
                                If you careful you can drill and tap out the broken stud and replace it, originals are Imperial size whitworth thread but you could tap out to 8mm and use a set screw and once tight (maybe use a bit of ‘locktite’ as well), cut the head off to length.
                                The white metal alloy ones need a bit of care though as the corners can break away when drilling/tapping.
                                #24310
                                Tim Greg
                                  Thanks for your help David, I will have a go at drillin out to 8mm.
                                  Thanks Tim
