Heater installation
Traction Owner’s Club Forums General discussions Heater installation
  • This topic has 3 replies, 3 voices, and was last updated 5 years ago by Garrett Maguire.
  • #27982
    Garrett Maguire
      Hi there fellow members, I was going to install a smiths type heater in my car. Does anyone have any tips/advice on how and where to tap into the cooling system for the flow and return pipes ? Thanks in advance, Garrett.
      #27983
      Jack Peppiatt
        DSCN5641
        Hi Garrett, I fitted a heater and this was my plumbing arrangement. I bought ‘T’ hose fittings to put into the flow and return from the water pump, a valve to shut off the flow to the heater which is mounted on the side pontoon and only just visible in the picture. I used a Clayton heater, still available, which has a better heat output than the original Smiths version with two doors. I found that having a variable rheostat on the fan speed was useful, the heat output can become too much. I fitted air bleeds in the smaller hoses in the cabin, but they turned out to not be necessary. If you would like more detailed photos please let me know. I got hold of a Citroen advance control lever, which I have mounted below the dash to turn the heater on and off.
        • This reply was modified 5 years ago by Jack Peppiatt.
        #27985
        David Selfridge
          Hi Garrett, I plumbed my Clayton heater similar to Jack, fixing it to the bulkhead using the bolts already there. The double hoses were then covered with spare matching carpet, held in place with narrow cable ties, 440DA52C-86ED-4530-B11D-09C5D31BC79C6E8CB5C3-39BC-45E5-AD1B-B1FF4E726930(which sink into the carpet) this blends in with the interior carpet and is hardly noticeable. The cable ties can be easily cut, should you experience a leak at the heater.
          Davy.
          #28000
          Garrett Maguire
            <p style=”text-align: left;”>Thanks for your replies, Jack and Davy. Thats interesting about the Claytin heater. Thanks Garrett.</p>
