Hints For Removal And Re-installation Of Bonnet And Grille
Traction Owner’s Club › Forums › Technical › Bodywork & interior › Hints For Removal And Re-installation Of Bonnet And Grille
  • #38799
    David Horsley
      Please may I have some tips about the best ways to do this ?
      #38801
        To remove the bonnet- undo the screws front and back and disconnect the bonnet stays. Get a friend on one side and lift it off and put it somewhere safe. To remvoe the grill, get underneath the front of the car and start undoing the bolts on both sides and then the bolts on the upper side. Installation is do the same thing in reverse.
        • This reply was modified 3 months, 3 weeks ago by Larry Lewis.
        #38805
        Robert Filbey
          Thanks Larry.  I’ve taken the bonnet off before (and yes, it is definitely a two person job when it comes to removing it) but haven’t looked closely at the grill before.
          Kirk
          #38807
            For those like me who have no friends, I can confirm from personal experience it is possible to remove a bonnet single handed – and that also includes a 6-cylinder.
            <span style=”font-size: 20px;”>Disconnect the bonnet stays at the rear of each bonnet leaf….. but first take a photo to facilitate correct spring orientation when refitting.</span>
            <span style=”font-size: 20px;”>Remove the two screws and plates attaching the hinge to the bulkhead and radiator.</span>
            <span style=”font-size: 20px;”>Place a cloth on top of one half of the bonnet and ensure the catches on that half are located to stop it moving accidentally.</span>
            <span style=”font-size: 20px;”>Open the other bonnet half and fold it completely over to rest on the cloth on the fixed half.</span>
            <span style=”font-size: 20px;”>Release the bonnet catches on the lower half.</span>
            <span style=”font-size: 20px;”>Grip the bonnet assembly by the rear catch of the lower half and the hinge at the front and lift it clear of the car taking care to avoid the headlamp.</span>
            <span style=”font-size: 20px;”>I normally place the bonnet on the lawn unless it is going to be off for some time.  </span>
            <span style=”font-size: 20px;”>Replacement is the reverse of the above but first place cloths over the bulkhead and across the top of the rad area to prevent damage as the bonnet is fitted.</span>
            <span style=”font-size: 20px;”>Put the folded bonnet roughly in postion and then open it up to get correct alignment.</span>
            <span style=”font-size: 20px;”>Once it is correctly positioned, clip the four bonnet catches to hold it securely whilst replacing the front and rear hinge fixings.</span>
            <span style=”font-size: 20px;”>Finally, replace the two bonnet stay pins and springs.</span>
            <span style=”font-size: 20px;”>Even more finally, have a cup of tea.</span>
            B…..<!–/data/user/0/com.samsung.android.app.notes/files/clipdata/clipdata_bodytext_260803_235659_517.sdocx–>
            #38811
            David Horsley
              Thank you very much, everyone.
              My adult son is going to help me take it off – I wouldn’t dare using Bernie’s solo method as I have one of those long-haired Art Deco radiator mascots and therefore can’t fold the bonnet right over !
              I guess it would be a good idea to mark the position of the bolts through the various elongated holes in the grille.
              #38825
                Another thought …
                If you are happy with the current alignment of the grille and bodywork and are only after access to other parts,  you could remove the wings and grille as one assembly.
                It takes little or no more time, two people can eeasily lift it clear it and it certainly makes both access and reassembly a great deal simpler.
                #38827
                David Horsley
                  It’s just the bonnet and grille that needs to be taken off, Bernie.
                  When I had the 1934 Hudson, six of us worked together to take the wings and grille off as one unit. Even with that many helpers, it was very tricky and just three of us re-installed them separately with a lot less anxiety (and much less swearing !).
                  #38829
                    David,
                    I’ve no experience of Hudsons but with a Traction, I promise you it is a pretty simple 2-man job and, importantly, eliminates the headache of re-aligning the grille and wings.
                    Bon courage.
