John Gillard
  • #24226
    Norman Anderson
      Hi Folks,
      I’ve lost contact with John Gillard. Emails to citroenclassicrestorations@btconnect.com seem to vanish into the ether.
      Can anyone help?
      Thanks, Norman Anderson
      07967 835646
      #24234
        try him on his mobile- 0776 3144598 good luck! He’s now in Kent, near Tunbridge Wells.
        #24236
        Norman Anderson
          Thanks Larry, will give it a go. Hope you are well.
          Best wishes, Norman
          #24256
            Norman,
            Depending on your success with JG …
            1) – The windscreen frame of a Light 15 is part no. 221217 which appears to be the same as that of a pre-’52 Légère so I do not believe you will have too much difficulty in locating one if you need to.  I have contacts in France for second hand bits if required.
            2) – I can confirm I do have a UK contact capable of “scumbling” should you need it.
            B…………
            #24271
            Jack Peppiatt
              Hello Bernie,
              Might I trouble you for the details of the scumbler please, my window surrounds are in a fetching shade of cream/magnolia and would look better grained
              Regards Jack
              #24290
                Jack,
                I shall send you his details and other info in a personal e-mail.
                B……………..
