New member looking to contact Mick Popka
Traction Owner’s Club Forums General discussions New member looking to contact Mick Popka
  • This topic has 5 replies, 3 voices, and was last updated 5 years ago by Paul Barnard.
  • #26194
    Peter Kerr
      Hello,
      I’m based on Southern California and have just purchased a French 1951 11BL. It has a lot of needs – primarily interior and floor so its going to be a while before I get it on the road.
      In researching I came across this link that mentioned Mick. I’d like to ask him about some details. Is he a member here?
      https://www.tractionavant.ch/Berichte/Technik/Elektrische/Traction.php
      Thank you
      Peter Kerr
      #26198
        That electric Traction conversion was done by John Gillard a few years ago. I did some work on it myself when I was there. It’s a Familiale.
        #26199
        Peter Kerr
          Hi Larry,
          Thanks for responding. I’m curious how the gearbox held up. My understanding was that these were OK in normal use but a bit weak. I’d have thought the electric motor would have caused it some distress…..
          I’m considering something similar but using a different gearbox. It would be simpler to use the stock one….
          #26195
          Peter Kerr
            IMG_1573IMG_1575IMG_0422TA Floor - Copy
            Here are some pictures as it sits now. I’m not sure why it was lined with wood – maybe someone confused European cars with a sauna?
            #26203
              As I recall the gearbox only had reverse and second gear as it was only to be used as some sort of promotional vehicle for an architectural firm. At first there was too much power from the electric motor so it had to be adjusted to give out maybe 40 hp. I did see one of John’s employees take it down the street and it went like a rocket!
              A wooden lined Traction. I’m speechless.
              #27307
              Paul Barnard
                Hi Peter
                If you still want to contact Mick P – I notice that he’s on Facebook.
                Cheers
