Is this a Slough starter motor?
Traction Owner’s Club Forums 6 Cylinder Technical Is this a Slough starter motor?
  • #36955
    Thierry Gest
      Hi
      I have a “spare” starter motor and am trying to get confirmation that it is for a Slough model and an approximate value in order to sell it.  Mine is the green one on the left and fits an 11BL. The mysterious one on the right is smaller (diameter 10.7cm, length approx 30.5cm).  Plenty of markings….LEYS….A538…D…12…50.
      Thanks for your comments.</p>
      • This topic was modified 1 year, 1 month ago by Thierry Gest.
      #36963
      Thierry Gest
        #36967
          Markings suggest it is 12V.  12V units are smaller diameter than 6V.
          Does it have the recess in the bendix housing to accept the fixing bolt?
          #36969
          Thierry Gest
            Yep.
            #36975
              <p style=”text-align: left;”>If bendi. Housing diameter and postion of holf match up with your 6V unit and Bendix teeth are also same, suggest initial bench test to see if 6V or 12V.</p>
              Assuming all matches and it runs on appropriate Voltage, try it in an engine.
              Even if it fits and works, value will still depend on condition of brushes, commutator, etc.
              #36981
              Thierry Gest
                Thank you.
                #36995
                  This doesn’t really answer the question but it might help – http://www.classicvehicledata.com/wp-content/uploads/2013/01/lucasstarters46to60.pdf
                  #36997
                    in fact even better is this link which has info on all Lucas stuff from 1945 to 1960 https://mgaguru.com/mgtech/books/lucas400e.htm
                    #36999
