Reconnd Master cylinder leaks
Traction Owner’s Club › Forums › Technical › Brakes › Reconnd Master cylinder leaks
  • #25454
    Christopher Smith
      slough built 11B 1952.. bought a resleeved  master  and  reconditioning  kit.Thought I had assembled  correctly  but on bleeding the  system fluid  leaks  back around  push rod into cabin !  The  new parts  don’t  quite  match the  diagrams  in the  manual  Does  any one know  location of  clear  photos  or  diagrams  so I can check my  assembly??
      #25455
        Does this cut away help?
        master
        It’s from a comprehensive article on brakes in Floating Power Vol 37 2013 issue 6 available in Members area https://traction-owners.co.uk/wp-content/uploads/2017/03/Vol-37-Iss6.pdf
        • This reply was modified 7 years, 2 months ago by David Faulkner. Reason: Added link to item
        #25457
        Christopher Smith
          Thanks very much Perfect . Chris
