Side/Parking Light
Traction Owner’s Club › Forums › Technical › Electrics › Side/Parking Light
  • #37851
    Robert Filbey
      I have a French built 1953 BL.  I’m trying to figure out how to access the side or parking light on the driver’s side of the car.  This is the small light at the top of the door pillar.  I thought maybe one just carefully pries the light assembly from the door pillar surface, but I thought I’d ask before doing any permanent damage.  Appreciate anyone’s advice or guidance on this.
      Kirk Filbey
      #37853
        The light does come out by gently prying with a flat-edge tool. A wooden paint stirring stick with a sharpened edge would work without damaging the paint.
        #37855
        Robert Filbey
          Thanks Larry!  I’ll give it a go this weekend and report back.
          Kirk
          #37863
          Robert Filbey
            Larry,
            Thanks again for your guidance.  I was able to successfully remove the side light (see picture).  The discoloration around the light fixture hole is a bit of dust, paint was undamaged.  I dismantled the light fixture, cleaned up the electrical connections and now the light works again!
            #37867
              Glad I could help!
