Steering Column Bushing
Traction Owner’s Club Forums Technical Suspension & steering Steering Column Bushing
  • #23022
    David Selfridge
      I have discovered the steering column on my Traction  seems to be floating, especially when braking and a sponge type rubber falling onto the carpet. Is there a rubber bush internally to the steering column and how to I fit.
      Davy
      #23023
        Davy,
        Plate 17 in the spares book shows three rubber bushes in the column assembly.
        600368 –  22.1 x 36.7 x 28.6 long
        601854 – 37 x 47 x 40 long
        602169 – 26(?) x 43 x 32 long
        Access for any is almost certainly going to entail dismantling the column to a lesser or greater extent.
        B………….
        #23024
        Peter Fereday
          Davy
          My French car has another rubber bush at the top of the steering column where it mounts on the dash – part number 602133. If yours has this and it is shot it could cause the column to move about .  But yours is an old Slough car right??
          Peter
          #23025
            The bushing between the column and the tube it rides in, right? I just changed that bushing in my 11B this week. Franssen has them. It’s a pain, the outer rubber part had to be shaved with a razor blade to make it fit.
            #23112
            David Selfridge
              Peter, My Traction is a Slough 1938 Light 12
              Thanks to all for answering my post.  If my memory serves me right, some time ago someone posted about this problem and they used heater hose to replace steering column  bushes, at the time it did not affect me so did not take much notice.
              Davy
              #23113
                It’s true – don’t know who posted it, and there’s no detail – but for what it’s worth here it is:
                https://traction-owners.co.uk/forums/topic/steering-wheel-removal-2/
                David Selfridge
                  Hi Chris
                  Thanks for searching and finding the post, much appreciated.
                  Davy
                  #23134
                  David Selfridge
                    Thanks to Bernie and all others for your help, I ordered all required from Chris @ TOC Spares and received just today.
                    I will post when all is fitted and any difficulties experienced.
                    Thanks All
                    Davy
                    #23182
                    David Selfridge
                      I have received the total number of bushes required for my Tractions steering column repairs from Chris @ TOC Spares. I will not able to fit at present as I have a two journeys planned over the next few weeks would it do any damage if this work was delayed to after these journeys. (Not long trips)
                      Davy
                      #23193
                        How long is a piece of string …..?
                        A little movement at the wheel (top) end of the column is likely to have minimal effect at the bottom but a lot of movement might put undue strain on the rack.
                        If all the loose rubber bits have now fallen out I would guess it is unlikely to get worse – but sod’s law will always prevail so assume it will.
                        The answer has to be – it depends how bad it already is and how far you are going.  Only you can tell.
                        B………………..
