Ok I am stumped. Undone bolts and removed wheel from boss. Undid big nut holding boss onto column. Using a puller I am trying to get the boss off the column. Having used impact wrench and heat the damn thing is not moving, any ideas?
Use a LOT of heat and the biggest puller you have. It will come. There’s no other way. Years ago I did that on my 11B and melted the rubber bush in the column but replaced it with a length of heater hose. It’s a pain but it will come off.
You are putting the puller claws or whatever it has at the base of the hub, not around the flange that the wheel bolts to, correct? I did that once and broke it off the hub. Then the real fun started! 👿
Yes! After a lot of heat and a lot of swearing it came off. Now the fun begins.
Author
The forum ‘Tech Torque’ is closed to new topics and replies.
