Sun visors for a 49 BL?
  • #4438
      Does anyone have them? I’d appreciate any help!
      #6889
        Larry,
        my 1949 11BL has one on the drivers side.
        There never has been one mounted on the passenger side, no sign of any fittings.
        The visor has a metal frame and a piece of thin gray fiberboard in it, 2 mm thick.
        Don’t have a photograph I’m afraid, but could get one if you want to see it.
        #6890
          Mick that would be good, might be able to fake one if I knew what it looked like.
          #6891
            Here is an example Larry, Der Franzose sell them for 106 euro, image is for a post 52 car but gives an idea what your looking out for, though I’m not sure what a pre 52 one looks like. Hopefully someone will post an image soon.
            #6892
              #6893
                There’s an auto jumble coming up here in December, might be able to find something I could use. thanks for the picture, Den.
                #6894
                  #6895
                    The difference between the earlier and later sun visor is that the earlier model has two fitting points and only works in “one direction” – Up, Down or any position in between, but always parallel to the windscreen.
                    The later version has a single fitting point which permits the visor to be moved to the left of right to block sunlight entering via the door window permitting movement from 0 Degrees to 90 degrees to the windscreen.
                    Look very closely at Den’s photo and you will see the second fitting point to the left of the windscreen wiper motor.
                    I think there were some 3rd party accessory sun visors that were available which were in dark green or blue perspex
                    #6896
                      My 54 11B has blue perspex visors as that was all that Depanoto had in the 1980s. I didn’t buy them but had them made for a lot less money and I had no clue what an original one was supposed to look like.
                    • The forum ‘Parts Wanted’ is closed to new topics and replies.
