Tow Bar
  • This topic has 10 replies, 5 voices, and was last updated 1 year ago by Bernie.
Viewing 11 posts - 1 through 11 (of 11 total)
  • #23632
    Non Member
      Do any members have an experience of fitting a tow bar?  I have a ’54 11B.  We have bought an amazing 1970’s folding caravan and want to tow it behind the traction.  Looks to me like the bumper is the only strong point for fixing.
      David  Bloxam
      #23640
        David,
        I have been towing with Tractions for many years.  There are several towbars on the market but, in my opinion, the best type is an original design which is constructed from a pair of shaped parallel tubes running under the car, bolted through the boot floor and cantilevered with clamps at the rear torsion bars.  There are several sizes depending on model and big/small boot.
        Normale Tow Bar
        I have a second hand one for a Légère for sale and I think I also have a brand new one for a Normale available because it is not quite right for my 15/6 for which it was bought.  Let me know if you might be interested – or just want a bit more info – and I shall be happy to contact you off-line to discuss further in detail.
        Bernie.
        #23641
          Relevant to the original question Bernie, can I ask from your own experience what sort of weight a Perfo Engined Legere would ‘comfortably’ tow (assuming a standard 9:31 diff) and the maximum allowable bearing in mind the car weighs 1,040 kgs please.
          #23642
            David,
            In the 80s I regularly toured with an Avondale Mayfly caravan – just under 1 tonne fully loaded – behind the Normale.  The only problem I ever experienced was in Scotland on a cold damp morning when I had to wait for the engine to warm up enough to tackle a steep unmade track out of the campsite.
            I also regularly toured Europe and Scandinavia with a trailer tent.  The only problem with that was that it had little or no effect on the car’s performance and, because you could not see it through the rear window, it was easy to forget it was there.
            In 2012 I towed the same Avondale caravan to Harrogate  with the Legere which had a 10 x 31 cwp.   That was straight up the A1 and the car did not have any problems.  However it did struggle on a couple of Gloucester hills when I used it to tow the Cloverleaf on a trailer to a meeting in that region.
            I have never seen any official (Citroen) figures re towing capacities but the following general information is gleaned from the web where there is a plethora of confusing information:
            • If you passed your driving test after 1 January 1997 and have an ordinary category B (car) licence, you can: Drive a vehicle up to 3.5 tonnes or 3,500kg MAM towing a trailer of up to 750kg MAM. Tow a trailer over 750kg MAM as long as the combinedweight of the trailer and towing vehicle is no more than 3,500kg.
            Hope this helps,
            b………………
            #23647
              Thanks Bernie 1 tonne = 1,000 kgs so that’s possibly the maximum and a good starting point.
              Licence isn’t an issue for me, but the 750kg is interesting as that appears to be the ‘unbraked’ maximum for most ‘modern’ cars that I have owned.
              Thanks for the input which will help others.
              #23650
              Non Member
                Thanks Bernie, i’d be really interested in the tow bar. The caravan weighs next to nothing and would be fairly easy to tow behind a bicycle!
                Can I give you a call?  My direct email is davidvernonbloxam@outlook.com.
                #23653
                  David B – I have sent an e-mail
                  David F – the trailer tent had no overrun brakes but, of course, the caravan and car trailer booth do.
                  B…………
                  #23655
                  Richard Larter
                    David
                    I have recently made a tow bar for my Legere using Bernie’s design and it tows very well but I did locate it on the large diameter chassis tube with large U bolts rather than the torsion bars. All trailers above 750 Kg have to be braked irrespective of the towing car.
                    Cheers
                    Richard
                    #23656
                    Non Member
                      Hi Richard, thanks for the info.  The trailer is braked so no issues there.
                      Cheers
                      David
                      #37039
                      David Selfridge
                        <p style=”text-align: left;”>If I had to tow  a traction, where to I attach the tow rope.
                        Davy Selfridge</p>
                        #37041
                          Around the lower suspension arm …. but make sure it is not going to catch on the wing/grille when the tension is on.
