What is this in the dash?
Traction Owner’s Club Forums Technical Electrics What is this in the dash?
  • #38299
    Richard Morris
      Does anyone know what this is in my dashboard? About 1cm diameter and 2cm deep. With +ve connection. The car is on 6v.
      #38305
        Richard,
        I’ve never seen one before but would make an educated suggestion it would have been a power source for a period accessory such as a screen demister or maybe a parking light.
        B…
        #38307
        Richard Morris
          Thanks. Someone on the FB group has suggested it could be a broken pull switch. I think I’m going to remove it and put an indicator tell tale there instead.
          #38309
          Richard Morris
            And James geddes says it’s a power take off , possibly for a lamp.
            #38311
              I’ve now seen your Facebook post with the picture of the whole dash.  There is already a parking light switch, above the indicator switch so that part of my suggestion was obviously incorrect.
              Sounds like an indicator telltale will be a good use of the existing hole.
              B…
              #38315
                Richard,
                I unerstand somebody in the Motherland has confirmed it is the same as their screen defroster/demister socket.
                I have a period 6V demister (somewhere) in my bits.  I shall look it out to see if it uses a similar power connection.
                B…
