Window Channels
  • This topic has 5 replies, 3 voices, and was last updated 6 years ago by Bernie.
  • #25856
    Christopher Smith
      Can  someone  point me to any articles/photos  on how  to secure the  window  channel  with ths  special  metal  clips  (  1951  L15 ) Thanks  Chris
      #25857
        Chris,
        Sorry, no pictures but ……..
        The clips need to align with relevant slots in the door frame.  I suggest initially fitting the channel without the clips then placing chalk marks in line with the slots to assure correct location of the clips.
        You can then remove the channel and fit the clips.   With the long “tail” of the clip pointing to the outside of the channel when it is fitted to the vehicle, push the two tangs through the bottom of the “U” section of the channel from the outside and fold them over inside to secure them.  You may need to punch suitable slots through the trim first with a flat-blade screwdriver or similar because the channel can be quite easily damaged.
        When fitting the channel, the tails of the clips should all fit into a slot and the two loose ends should each be secured in the steel side guides in the door by a steel tag which must be bent to fit into and retain the channel.  If these tags are damaged or missing (not uncommon) – or if the channel has been cut too short to give a tight fit – I recommend using an adhesive to ensure the ends are located and secured.  This should minimises the risk of the channel being dragged down by the glass.
        B.………..
        #26304
        Non Member
          Hi – this may be me  – but – I still can’t work out how to hold the door glass channel rubber (216-145) in place using the “hook for the glass channel” (216-146). There do not seem to be any slots in my door frames to insert the hooks (as Bernie describes)
          IMG-1625
          Or is it easiest just to glue the channel to the frame?
          Many thanks
          Steve
          #26306
            Steve –
            IT IS YOU  …. Or perhaps lack of clarity on my part.
            You are presenting the clip the wrong way round. i.e. the “long” end (currently between your thumb and finger) is the end that goes into the oval shaped hole in the door.
            BUT –  fist of all you have to attach the other end of the clips to the channel – as described in my second paragraph, above –
            <p style=”text-align: center;”>clip fixing</p>
            – and then offer the lot to the door as an assembly.
            I removed my interior window trim to take the following pictures of the top edge of the door frame, looking up from the aperture where the glass descends into the door.
            If you download and zoom in, you will see the “tail” of the clip needs to be “fettled” to pass into the slots and hold the channel at the correct angle.
            .IMG_20200314_123928 (002)A
            IMG_20200314_124006 (002)
            IMG_20200314_123937 (002)Good luck – again.
            B.……….
            #26314
            Non Member
              Excellent – thanks so much Bernie for all the trouble you have taken to explain this – I had been looking for a narrow slit to fit the “tail” of the clip into and not recognised that the oval cutouts (all around the window) are the correct venue. Everything has now gone together nicely.
              #26317
                Invoice for the specially commissioned illustrations is in the post!
                B………..
