Reply To: New member – Looking for help on restoring a Big 15
Traction Owner’s Club › Forums › General discussions › New member – Looking for help on restoring a Big 15 › Reply To: New member – Looking for help on restoring a Big 15
#33821
Mark Breugelmans
    Hi Chris,
    Sorry for the lack of reply, unfortunately I had to take a break working on the car for personal reasons, but I’ve finally started looking at this again. I successfully managed to free the brakes on left rear wheel by rotating the upper cams inwards.
    The cam nuts were seized and it took a lot of penetrating oil and a 6 sided socket with a long lever to free them.
    Unfortunately the right rear wheel has been less forgiving. One of the cam nuts was partially rounded and I’ve made it worse trying to free it. The drum is refusing the budge. I also tried tapping around the edge of the drum with a nylon hammer after releasing the hub nut, but no luck with that approach either.
    I’m considering a heating the cam nut, filing some flats in it, or trying a nut extraction socket. Or perhaps I could heat around the drum and hammer it off?
    Any suggestions would be most welcome.
    thanks,
    Mark
