1950 Lt15 small boot floor and cover plates
Traction Owner’s Club Forums Technical Bodywork & interior 1950 Lt15 small boot floor and cover plates
Viewing 8 posts - 16 through 23 (of 23 total)
  • #23996
    Patrick Russell-Jones
      This is a close up of the retaining clip. Note that there are also two anti rattle stoppers on the lip, one visible in this shot.
      IMG_1856
      #23998
      Jack Peppiatt
        Patrick, thank you. that is now completely clear and understandable. The explanation added the cream. I am in your debt
        Regards Jack
        #29793
        Jack Peppiatt
          Following my earlier question on the boot floor/plate/cover etc, I am now reconstructing the rear valance and lower boot floor. I have a new lower boot floor, reusing the old hinges and have a new outer valance.
          Does anyone have good photos of  the boot/valance structure during restoration please. The fellow doing the welding is wondering about the hinge reinforcement plates and the brackets that attach the hinges to the lower boot floor etc. I am unable to find an exploded drawing of the components or clear resto photos. any help would be much appreciated
          thanks
          Jack
          #29794
            Jack
            This might help
            Patrick
            WIP 1B s
            #29795
            Jack Peppiatt
              Thank you Patrick, again, you have apparently  been through this process. Underneath plating on the vertical from the upper to the lower floor, was the original, which apart from some minor rusting on the bottom edge  which was easy to cut away and weld a 25mm strip across the width.
              We have a new lower boot floor with reinforcing plates for the boot hinges and outside that we have a new valance. Are we missing anything else do you think? I have not been able to find an exploded parts drawing or any other illustration.
              Thanks for your assistance, much appreciated
              #29797
                Jack
                A couple more pictures. I think you have everything. The new floor provides the lid hinge fixing points and then you have the valance panel filling the space between the wing ends (photo2). Photos courtesy of James Geddes who did the work for me.
                Patrick
                Lt15 Boot
                Lt 15 boot 2
                #29796
                Philippe Allison
                  P1030422P1030223P1030436P1030437P1030444P1030452P1030453
                  Jack, some before and after pictures of my Slough Big 6 basically the same. Hope it helps.  Regards Philippe
                  #29808
                  Jack Peppiatt
                    Dear Philippe and Patrick,
                    Thank you both for the excellent photos, they are exactly what was needed and have resolved the issues we had
                    I am most grateful
                    Regards Jack
