1952 Paris built Normale RSJ 834
Traction Owner’s Club › Forums › Forum Archive › Traction Owners Club Forum › Your Project › 1952 Paris built Normale RSJ 834
Viewing 15 posts - 166 through 180 (of 191 total)
  • #6817
      Oh dear not only am I a presumed member of the Traction Moaners group here on the pesky forum I also am one of those who are risking life and limb for removing the volute springs and using a modern alternative. In the latest issue of FP it is mentioned that the springs are there to solely stop the engine from moving side to side and that the rear block mounting takes the strain. I am new to Tractions but with just a borrowed manual and pure logic I know this is wrong. If someones car is set up in this way no wonder they have noise and vibration. Yes I had concerns re the engine mounting brackets and their ability to do the job being asked but after actually thinking it through and taking a good look I am pretty sure they will be fine.
      #6818
        Well I can tell you (from experience), when that rear block is supporting the engine then the car is un drivable.
        When I swapped my clutch and quickly put the engine back in before a 3 day outing, the noise and vibration made it a very unpleasant experience. When the weight and stance was adjusted back on to the engine mounts and there was a good 5mm gap around the rear block, the car came back to normal.
        So if these rubber mounts are better (which recent reports suggest they are) then it is the only way to go for the future, BUT that is only if you want to enjoy driving the car and not just have a perfectly original museum piece resting in the garage.
        “proud of being a moaner if it gets more of these cars back on the road”
        #6819
          You have to remember that the DS uses a rubber mount system (different set up to a Traction though) without the rear block on the bulkhead, so Citroen moved on from the 1934 engine mount design in 1955.
          It’s up to individuals to decide whether to go down that route and looking at tripyrenees long restoration thread I can see pictures showing how the “Normale’s” mounting brackets are longer, so will they will have a bit more “leverage” on them than the small bodied cars.
          #6820
            Not a good day. Moved to the other side of the car on Thursday evening. I had left this side as it seemed the best of the two so I was surprised at what I found. Bear in mind there were only a couple of small bubbles in the paint. Look at the pictures these show what I found on removal of the old rain gutter. I now have to weld in new metal and do far more work on the body in this area than I was expecting. I am convinced now that fitting the new gutters with glue and stainless steel rivets are the way to go this will make it easier in the future to prevent rust.
            #6821
              I have the brackets for the door mirrors and now I have the mirrors……. I am so tempted to customise the Traction……………………………………..
              #6822
                I dare you…. and then crash the birthday bash with them 🙂
                #6823
                  The mirrors are going on for sure. Not going to bother with the birthday bash. It is my wife’s birthday on the Sunday and originally when we thought it was going to be a few days she was happy to go to the bash. Since it seems that the Sunday bit is a afterthought add on and from how it reads nothing to do with any of the others we have decided not to go. Shame as a friend will be there for the full 3 days I think.
                  #6824
                    Hello fellow ‘forum whingers’, sorry, just checked and it’s actually ‘Traction moaners’. Baz where did you get the brackets from? They seem to be expensive, but of excellent quality.
                    #6825
                      The Sunday for those that had not already booked is with all those attending. If you’re quick there may be space available at the barbeque on the Friday evening.
                      #6826
                        Sorry but which bracket?
                        #6827
                          It is my wife’s birthday that weekend and originally we were going to make a weekend of it in that area driving the car and attending the rally. Since it was so up in the air and it was not fair ruining her weekend I have organised something else. I hope everyone has a good time and am still pretty angry with how it was organised at the start and then the subsequent attitude.
                          #6828
                            I wrote the piece in F-P. Thanks for your comments, it’s always good to get some feedback. I don’t really want to cause trouble but I’ve done a bit more research to find out what those volute springs do and what the rear mounting block does. i thought I’d try and get to some numbers.
                            I was going to change my rear mount block anyway because I’ve had the car a long time and never seen it. So I did that today. The cover came off easily and there was the rubber block sitting perfectly in the middle of the hole – as measured by running my finger round it. I changed it for the new one – per Peter Larsson at CTA Sweden the typical problem is that the rubber hardens over time. The new one felt a bit softer so in it went.
                            There are wear marks on all four sides of the cover – a similar patch of shiny steel showing through the paint in the middle of each surface.
                            The clearance between the block and the cover is about 3mm on each side, allowing for where the block sits in the cover – both the block and the cover are tapered.
                            So the question is how much load is taken by the volute springs when the 3mm clearance is taken up and how much is taken by the block?
                            That requires knowing about the spring rate and the loads.
                            I can’t find any specification sheet for the volute spring – but I have found one for something similar made by a company called Don Springs. The smallest one in their catalogue appears to be the same thing – expect the height of the strip material is twice that in the car. This has an effect of doubling the spring rate which is quoted as 10 kg/mm – so from that I can estimate that each spring in the car has a spring rate of about 5 kg/mm. From pushing the engine around without the rubber block in place that I would say it feels something like that – I didn’t measure it though but that’s the figure I’ll use.
                            So what about the loads? The springs can clearly support their share of the engine statically – the load being shared with the gearbox mount which also controls the fore and aft motion. Clearly the engine moves on its springs when it is running – this will happen as a result of three things – out of balance rotational forces, bumps in the road and torque due to acceleration and braking.
                            I fired up the engine without the cover on the mounting block. It hardly moved as it is pretty much in line with the gearbox mounting and the engine’s centre of gravity – so any rocking from out of balance forces is going to be on an axis through the middle of the block which therefore plays no part in preventing it. The springs will oppose the rocking but they provide no damping. Solid rubber blocks will also provide damping which would be a good thing.
                            So what about when the car goes over a bump? Apparently the unsprung part of the suspension can see 5g on a bump but the body itself sees far less because of the suspension. 1g would seem to be a high estimate for the car body to experience but some papers suggest it is a measured figure. If the engine was caused to move at that vertical acceleration it would double in weight and whatever is holding it up will momentarily see twice the load – or it would if the engine mounting was solid. But it isn’t – the two springs combined have a spring rate of 10kg/mm. If the engine weighs 300kg, half of it is on the springs – the other half is on the gearbox mount. So adding another 150kg would cause about 15mm deflection at the springs – which means about 30mm deflection at the rear (because the springs are half way between the rear block and the gearbox mount which is the pivot point). I don’t know if the engine weighs 300kg but it is not far wrong. So – if the springs are fitted and the block is missing the engine would move 30mm – i.e 27mm more than the block permits. If the springs are replaced by stiffer ones such that the displacement is no more than the 3mm gap, or the block is removed, the additional load on the new mounts (and brackets) is 270kg i.e 135kg per side. If you believe these figures that is – you probably shouldn’t really because I haven’t factored in the frequency of oscillation or damping coefficients or the spring rate of the replacement rubber blocks. But the point is it’s a significant number.
                            The other question was about when the car accelerates or brakes. This will be a bit more accurate because we know the maximum acceleration and braking figures – they are stated in the contemporary road tests – and we know the wheel radius and the distance between the drive shafts, and the engine mounts. We also know the mass of the car. Motor’s road test #4/48 says the car can accelerate from 0 – 30 mph is 6 seconds which is about 2.2 m/s2. At that acceleration I calculated the volute springs would each need a spring rate of about 61 kg/mm to keep the deflection to within 3mm. If none of the acceleration load is taken by the rear block, the load on each side due to the torque increases by 92kg whether the mount is a spring or a rubber block. With the 5 kg/mm springs you would have to take 73 seconds to accelerate from 0 to 30 mph for a 3mm deflection. The car can apparently decelerate under braking at 0.8g but braking loads are not taken through the engine mounts – well the engine braking load is but that must be far less the acceleration load.
                            So – I think I have shown that, as the car left the factory the rear block is taking a fair load most of the time the car is driving. If the block is taking the load, the springs are not doing much – they can only provide a load of about 22kg at the maximum deflection allowed by the rubber block. If the block is removed, the springs will need to be replaced by rubber mounts that are about 10 times stiffer and that they, and the brackets, will have to support the additional load which will be in the order of an additional 100kg per side. This is not a huge figure compared to the engine mass. But it is quite large compared to the load those brackets normally take.
                            I don’t recall suggesting that anyone was risking life or limb and since a number of cars have been running around with this conversion for some years, it seems they can take it. I don’t know how much headroom there is though.
                            I like to refer to this forum in the Citroenian and Floating Power and mention things that are discussed here to encourage people to have a look and join in. Not that I’m that prolific here. I’m not personally bothered about originality – certainly not on my own Normale. I just fitted electronic ignition today – I’m quite excited about that.
                              Hi Chris thanks for the detailed reply.
                              Your ideas are valid when using the original springs because they allow the engine to rise due to having a cup rather than a solid bolted option. The rubber mounts are bolted to the body and the engine is bolted to them this means the engine cannot lift. The mounts on the gearbox end need to be in good condition because they will do extra work. The actual metal engine brackets are up to the job but do need to be checked for any signs of stress fractures.
                              By the way most comments I make are said with humour in mind.
                              #6830
                                We have to remember also that these cars will never do what they were designed to do – meaning, they are not daily drivers, they are now mostly Sunday cruisers, so the amount of work they need to do has diminished significantly.
                                So the engine brackets will probably be able to suffer the odd trip around the country lanes where if they were subjected to the daily commute or delivering beer barrels then they might be a little fractured using the new rubber mounts over their lifetime.
                                Belt and Braces sort of comes to mind which I suffer from greatly when doing my projects. I have not yet changed to the rubber mounts and I recently changed my rear block so have at least the luxury of seeing if all the new fits are working correctly :o) If and when I decide to do a “BIG” rally then I will go for the rubber mounts which would coincide with an engine out preparation service anyway.
                                I know none of the actual committee would read this anyway, by maybe these Floating Power Technical articles could be “floated” on here for discussion, ripped to threads, added to etc. Just because it is printed in FP doesn’t mean it is the way forward…. I seemed to have learnt this over the past few years with all types of old cars on various forums.
                                You would have thought that after 60 to 80 years there would be a definitive way of doing it right ???
                                #6831
                                  Ian,
                                  Please be reassured that I read them all.
                                  My thoughts when reading the above response was that this needs to be forwarded to the Editor for future inclusion in FP.
                                  Were you aware that several technical articles have been uploaded to the “Members Only” section of the website because they were “too big” for FP?
                                  You can find them here: http://traction-owners.co.uk/members_only/toc-tech/toc-tech.pdf
                                  Mick
