๐ ๐ Mine were interfering with the running gear, they were so smashed up. The rear and bent into the valence, hence I had to replace the valence as it was beyond repair.
But as you can see my chrome has plenty of character ๐ ๐
@mpopka wrote:
@OSL282 wrote:
Haven’t seen a heat shield for the fuel pump before, was that on the car when you got it?
Standard fitting, I believe, Dave, as with the heatshield for the Dynamo and for the Carburettor.
They are the sort of thing that gets taken off and forgotten about when re-assembling (like the heater tube).
In places like the UK the difference is probably negligible, however if you encounter fuel vaporisation it something to try to eliminate the problem.
Given that my car took a lot of starting on the way to France last year which eventually lead to the 6v starter failing I decided to get a fuel pump heat shield from J Fransen (part 588.730)
Fitted it today and had doubts about there being enough clearance for the 1st and Reverse selector rod, but it’s working fine even if it does seem to ride up the inner side of the shield.
Hopefully not a waste of 22.49 Euro this summer ๐
I can’t believe I managed to put something up that has been helpful ๐ Hope it works for you and yes, I had to buy 3 heat guards (4 as I got the wrong carb one) and they are not cheap. ๐ฟ
So after driving the Traction Legรฉre yesterday I am fully motivated to get mine finished in time for the next Traction Universelle meeting which is actually on my birthday in April. It is a trip to the Tarbes Bourse d’Exchange where the Midi Pyrenean section will have a stand. I promised myself it would be ready for April as our work season starts, so I have plenty of goals to achieve.
So the head is now machined and in place. I adjusted the valves to the 0.15 and 0.20 clearance for inlet and outlet. All is good and I will recheck them when the engine is warm (that sounds so far away but it may not be now ๐ )
[attachment=2:kdkmq46n]P1070346.jpg[/attachment:kdkmq46n]
I installed the manifold – wow! that is tough. The two upper nuts are so hard to get tight as there is zero room in-between the pipes. I ground down two spanners before I got anywhere near. I also went a bit mad with my polishing wheel – let me know when I have gone too far ๐ ๐
[attachment=1:kdkmq46n]P1070348.jpeg[/attachment:kdkmq46n]
Finished off the air filter housing with its new label – hard to believe this was the original, now all fitted with a modern round filter inside.
[attachment=0:kdkmq46n]P1070349.jpeg[/attachment:kdkmq46n]
I need to get the engine on the ground in readiness to fit the gear box tomorrow. I think it will be easier to slide the gear box on than try to lift it to the engine and plus I am not sure the little workmate bench will take all the weight. So out with the lift again.
[attachment=2:3thevkwl]P1070350.jpeg[/attachment:3thevkwl]
On with the rocker cover for a little protection
[attachment=1:3thevkwl]P1070351.jpeg[/attachment:3thevkwl]
I was just unscrewing the bolts ready for the gearbox when one fell in behind the flywheel. Bloody thing dropped so it poked out but the head was caught inside between the flywheel and the oil baffles…… arrrgh ๐ฟ ๐ฟ So had to pull off the clutch and loosen the flywheel bolts and it dropped out. Will refit tomorrow and align the clutch again.
[attachment=0:3thevkwl]P1070353.jpeg[/attachment:3thevkwl]
I sent an email to Castrol to find out which oil I needed and they replied pretty quickly with Castrol Classic XL30. I will flush the engine first with 20w40 first a couple of times before putting in the expensive stuff. Any other recommendations would be appreciated.
I’ve been using Castrol Syntec fully synthetic 5W-50 in my cars for years now, after breaking them in on mineral oil. I know the debate about original type oil versus synthetic has been done to death in FP, but me I don’t like all that crud traveling through the engine and crusting up the insides, so I installed an oil filter as also described in FP.
When my engine was rebuilt I used the Castrol XL30 for the 1st 2 oil changes then switched over to Millers Classic 20w50 – Andy Burnett reckons it’s a waste of money and any 20w50 will do but the Millers has replacement additive for the Zinc of old which supposedly reduces wear and in the overall scheme of things it’s a small price to pay versus an engine rebuild.
Millers Technical support agree that it’s better to have any crud held in suspension and drained out with the oil, rather than being left to accumulate in the sump aka the Castrol.
Car has now covered 5k+ kms on the Millers oil and runs smoothly and quietly with minimal dirt on the magnetic drain plug when it’s cleaned at oil change time, still with no oil filter fitted.
Busy day today. Firstly I put back the flywheel, torqued it down and bent over the locking tabs. Installed the new clutch plate and centred it while tightening the clutch housing. All went fine.
Pulled over the gear box and slid it straight on. The engine now looks even bigger.
[attachment=2:yq44nf7n]P1070356.jpg[/attachment:yq44nf7n]
I had to disassemble the front of the car again, so off with the bonnet, grill and bumper. Lights were taken off as well as the cross member. An hour or so of preparation. Car looks like it did months ago now ๐ฎ
[attachment=0:yq44nf7n]P1070364.jpeg[/attachment:yq44nf7n]
It is so heavy, even to slide around on its stand. So out comes the engine hoist.
[attachment=1:yq44nf7n]P1070365.jpeg[/attachment:yq44nf7n]
Engine was then hoisted in taking care to wiggle the driveshafts on as they were the only thing to get caught. The rear engine mount slid into the box and I lined up the side mounts (with the help of my wife) and then dropped it in.
[attachment=2:3os6t97m]P1070366.jpeg[/attachment:3os6t97m]
In with the cross member and the angle supports – they were quite tough to get in, specially tightening the bolts but after an hour or so it was all bolted in.
[attachment=1:3os6t97m]P1070371.jpeg[/attachment:3os6t97m]
Starting to build up the engine with the accessories – got the gas pedal working perfectly but I need to get another choke cable as mine seems to have bent along the way and is not running smooth. Managed to connect up the starter cable and tried it for fun – first time the engine has turned over on its own since 1972 ๐ ๐
[attachment=0:3os6t97m]P1070374.jpeg[/attachment:3os6t97m]
Bolted on the water pump and installed the new alternator with new fan belt. Starting to look like an engine now. It is also very very big ๐ฏ
[attachment=0:3493d7as]P1070375.jpeg[/attachment:3493d7as]
Looking good! But wait, “gas pedal???” I thought you people called it a “petrol foot control device” Or something!
Were an ‘International’ community so some allowances have to be made ๐
Ian, as Den says, before rebuilding the front end, make sure everything works. As long as there is oil in the engine, you can run it for a minute or two without the rad and coolant.
Yep – guess what the only item I had not cleaned and prepped and boy what a state it was in. The gear change rods and mech. So last thing last night I cleaned it all up but today I will need to paint and grease it.
I have checked the operation of the clutch already which seems OK. I am not rushing this part, I want everything just right.
Keep the advice coming though as I am bound to miss something or install something only to have to take it all apart again.
Ian
OK – you knew this was coming.
Has anyone a couple of clear photos on how the gear rods are connected. i.e. which is 1st and Reverse and which is 2nd and 3rd. I have tried every combination and it has been a long time since I took them apart. A picture of the bulkhead connections would be good as well as the gearbox end. Or a schematic if there is one.
Did not help at all that the EZ Power Steering motor was fouling the change mechanism – it was fine until I connected the levers in the engine bay. I have had to take out the motor for now so I can get the gear changing correct first.
Also, is the clutch supposed to be that heavy ๐ฏ
[attachment=0:2rgu1166]P1070378.jpg[/attachment:2rgu1166]
