Viewing 15 posts - 106 through 120 (of 443 total)
  • #4835
      Excellent call, I will order some straight away and line the from to the bulkhead and the rear.
      I was worried about the thin barrier and all the little holes, I thought it might be a little chilly in the winter more than hot in the summer.
      Cheers
      Ian
      #4836
        That’ all very well Dave but noise in the cabin is part of owning a classic, or should be as is heat and cold.
        Regarding heat in the summer heat shielding is OK if you never drive your cars in the winter but I do (I have 3). So in my opinion open the windscreen and door windows in the summer if necessary and during the winter give the rear passengers a blanket (again these were always found in cars in the 40’s and 50’s). Not every one can find a period heater.
        #4837
          Do you want heat? Have a look at my website, http://www.southwindheater.com. One of the cars pictured in the gallery section is my 11B, the other a friend of mine’s 11B which has since been sold. They work a treat and are are easier to install than a Clayton heater.
          #4838
            Den, it doesn’t eliminate the noise, just reduces it to a level whereby you can drive at 55-60 and talk to passengers.
            As for heat in the winter, I have the original air feed from the radiator fitted which takes the edge off things in the winter, but the car is not uncomfortable to ride in and yes I use mine year round as well.
            #4839
              After driving my 2CVs I am looking for more comfort in my Traction so anything that will help this I will put in now. All my cars that I own are at least 30 years old, so I am used to suffering a bit.
              #4840
                I have finally got the dirtiest job out of the way. The cleaning, rust treatment and painting of the rear underside of the car. This was disgusting covered in years of mud and crap. I wired wheeled the lot with the rear suspension system still in place as I didn’t want to take this out for now, although it made the job ten times harder and there just a few places I need to get too once the car is off the lift.
                But I think I am getting there and it seems the thick layer of mud has preserved the steel as new ๐Ÿ˜€ with absolutely now rust at all.
                [attachment=2:31hn0l4d]P1060881.jpeg[/attachment:31hn0l4d]
                [attachment=1:31hn0l4d]P1060880.jpeg[/attachment:31hn0l4d]
                The torsion bar adjuster looks a little different now and it also has the ability to adjust now (and not rusted solid)
                [attachment=0:31hn0l4d]P1060883.jpg[/attachment:31hn0l4d]
                #4841
                  Once it’s back on the road your going to have to park the car up when out and about and put mirrors underneath like the ‘concourse’ guys do to show off how clean and shiny it all is ๐Ÿ˜Ž
                  #4842
                    You’ll need velvet ropes too, to keep the hoi-polloi at bay. :mrgreen:
                    #4843
                      Thanks – I was not intending to get it so shiny, I was just lucky that the muck came off easily leaving a spotless shiny metal surface. The top of the car will be the exact opposite for a year or so ๐Ÿ˜ฎ
                      I got busy putting back the rear axle parts as my goal is to get it back on its wheels as soon as I can. So the rear hubs and brakes were fitted.
                      I do like seeing the before and after shots though ๐Ÿ˜€
                      [attachment=2:37rw79cn]P1060787.jpg[/attachment:37rw79cn]
                      [attachment=1:37rw79cn]P1060888.jpeg[/attachment:37rw79cn]
                      Installed the handbrake cables but not before giving them a good cleaning, service and greasing. These original parts to stand the test of time so no need to buy all new parts with this renovation.
                      [attachment=0:37rw79cn]P1060885.jpeg[/attachment:37rw79cn]
                      #4844
                        I have fitted the new brake pipes to the rear axle too. They seem easy to fit at first but getting that last little bend int hem proves quite tough specially when there is always the threat of a kink, and they are too expensive to do that ๐Ÿ˜ฎ
                        I have one single pipe to fit and that is the front to back pipe but that will happen after I have replaced the front floor panel.
                        [attachment=2:tx68ddjm]P1060894.jpeg[/attachment:tx68ddjm]
                        [attachment=1:tx68ddjm]P1060895.jpeg[/attachment:tx68ddjm]
                        I made up the specialist tools for the brake shoe alignment after collating a lot of different documents together on the subject, thanks for all the help on this. I was lucky though as the rear centering tool is exactly the same as the 2CV tool so fitted perfectly over the rear axle ๐Ÿ˜€
                        [attachment=0:tx68ddjm]P1060889.jpeg[/attachment:tx68ddjm]
                        #4845
                          I am now finishing off the front brake alignment and then onto the temporary steering system fitting so I can man handle the car on the ground.
                          [attachment=0:1xs036fx]P1060897.jpeg[/attachment:1xs036fx]
                          #4846
                            Your doing a great job, keep up the good work.
                            On the brake pipes, I came across a small pipe bending tool in Aldi which does 6, 8 and 10mm pipes which was so cheap I just had to buy it………..
                            I have not had to use it yet, but no doubt it will come in useful one day ๐Ÿ˜†
                            #4847
                              I managed to get the car back on its wheels, first time since early this year. The whole suspension and drive chain is complete at last.
                              [attachment=2:3k5v7cjf]P1060899.jpg[/attachment:3k5v7cjf]
                              Then out into the open air a little dusty
                              [attachment=1:3k5v7cjf]P1060903.jpeg[/attachment:3k5v7cjf]
                              But after a bit of a wipe down it is shiny again…….. well until it all dried off and now it is back to dull black again ๐Ÿ˜€
                              [attachment=0:3k5v7cjf]P1060906.jpeg[/attachment:3k5v7cjf]
                              #4848
                                Tough day today, I started on the floor replacement.
                                Firstly I had to heat up and scrape the bitumen mess from the front bulkhead, what a crappy job that was and quite awkward getting in there too ๐Ÿ™ But most of it came off leaving just a shimmer of black that will be covered with the Fatmat sound/heat proofer http://www.fatmat.com . It may not be original but I bet citroen would have used something similar if it was available at the time and not that sticky tar stuff that is all over the car ๐Ÿ˜ฏ
                                I then cut out the front floor section and air hammered the spot welds off the surrounding ledge. That was a job and a half and I fell like I am getting into the touch restoration work now…. grinding and welding….man work ๐Ÿ˜†
                                [attachment=2:2q5296v5]P1060908.jpg[/attachment:2q5296v5]
                                I bought the replacement front floor panel from Josรฉ Franssen in Belgium. It was a good price but now I know why. How can a manufacturer not get the pattern right for the triangular sections underneath. It is not hard. And if the original cars are all so individual, then leave the bloody things off and leave the purchaser weld them on…. ๐Ÿ‘ฟ ๐Ÿ‘ฟ
                                See how much they are out of line (the thin strip is a piece I cut from the floor and that welding…. that is how it came)
                                [attachment=1:2q5296v5]P1060910.jpeg[/attachment:2q5296v5]
                                So I had to remove the outer two sections and place them in line with the existing section on the car and reeled them. A job that takes time which would be better spent drinking tea.
                                [attachment=0:2q5296v5]P1060912.jpeg[/attachment:2q5296v5]
                                #4849
                                  The panel is placed in until tomorrow. I need to put in the angled reinforcement sections on the surrounding edge. I tried using some really nice zinc coated metal today but even though I ground the surface off the welds were not holding, I had to knock it out and I even spend 30 mins running test weld on the bench but it was crap. Going to get some nice mild steel tomorrow and do a proper job ๐Ÿ˜•
                                  [attachment=0:3t8m4pi6]P1060911.jpeg[/attachment:3t8m4pi6]
